400 Rwhp
Old Feb 13, 2008 | 04:34 AM
js2fst's Avatar
Default 400 Rwhp
Can I change injectors spraying 100 shot wet. svo 30 or 42 which size? will I have to retune?
Old Feb 13, 2008 | 09:56 AM
Mike @ New Era's Avatar
Spraying a wet shot doesn't require an injector upgrade .
Old Feb 13, 2008 | 11:06 AM
js2fst's Avatar
above the 400 rwhp would a set of 98 injectors help? would I need to tune for this?
Old Feb 13, 2008 | 01:28 PM
If you have 400rwhp naturally aspirated , and you are spraying a 100 shot on top of that , then you need injecotrs already just on motor . But spaying a wet shot actuallly will generally decrease injector duty cycle when you use the nitrous . The only time you need to upgrade your injectors for nitrous is when you are spraying a dry shot .
