Walbro install, need help
Old Jul 16, 2003 | 01:15 PM
phenyxTA's Avatar
Default Walbro install, need help
I just finished installing the single intank pump. When I turned the key over I thought for sure I heard the pump buzzing but the car won't turn over. I checked the fuel pressure as I was cranking it and there was nothing. Thge only thing I can think of is I have the wires crossed. Isn't it black to grey and black to red?
Old Jul 16, 2003 | 03:58 PM
CAT3's Avatar
Restricted User
Default Re: Walbro install, need help
Hummmm cant tell you the colors, but have someone cycle the key on and off with a delay between and lay your ear down on the rear tray to hear if it is pumping or not. if it is you should be ghood to hook there. then check connections elsewhere?
Old Jul 16, 2003 | 07:45 PM
98,Ram,Air's Avatar
Pull the valve out on the fuel rail, hook up a hose to a catch can, turn the key and see what comes out.
Old Jul 17, 2003 | 05:03 AM
phenyxTA's Avatar
It was the wires. They get installed opposite from the stock pump.
