Racetronix question
Old Mar 1, 2008 | 11:29 AM
DanWS6's Avatar
Default Racetronix question
I put in the Racetronix 255 kit two years ago when I installed my procharger. I'm rebuilding my motor and will be putting down more power, so I'm guessing I'll need more pump. Is it possible to add a second intank pump to the kit or will I need to buy a completely new kit? If I can add a second pump how will that work with the wiring harness. I'd like to add a fuel controller (MSD or aeromotive) as well.
Thanks
Old Mar 1, 2008 | 07:34 PM
Mark98SS's Avatar
Check this thread:
https://ls1tech.com/forums/fueling-injection/856954-diy-twin-pumps-quick-cheap.html
Old Mar 1, 2008 | 08:06 PM
Lonnies Performance's Avatar
LS1TECH Sponsor
Dan,
While you can fabricate a lot of the wiring yourself for a dual pump kit, I provide a complete plug-n-play setup for your car. It is fully assembled & completely tested & ready to drop in your tank. Everything is OEM quality with weatherpack connectors & weatherproof relays. If you are looking for an easy to install & professional setup, feel free to give me a call.
Old Mar 1, 2008 | 10:14 PM
DanWS6's Avatar
Originally Posted by Mark98SS
Cool I'll look at it. Thanks
Originally Posted by Lonnies Performance
Dan,
That's what annoys me, I already bought the wire harness with the single pump. Wish I would've gone with the dual pump setup to start with. Guess I could always try to sell it. I'll give you a call when I'm ready to upgrade.
Thanks.
Old Mar 2, 2008 | 09:47 AM
LS1TECH Sponsor
I looked into trying to provide an upgrade for the single pump kit, but the pumps I use are slightly different. The single kit wiring will also need substantial modification & since I would only reuse 1 relay, plus some of the main feed wire, therefore my extra labor easily offsets any savings.
I realize your present investment is substantial.... this is why I suggest you sell your existing system instead of robbing parts from it. At least if you sell your present system, you will be getting a decent portion of your money back, plus you will then be starting with all new components.
If I can be of assistance, please give me a call.
Old Mar 2, 2008 | 10:58 AM
DanWS6's Avatar
Good points, thank you for the advice.
