Stock Regulator question?
Unfortunately, you will have to remove the one from the sender if you choose to do this, requiring you to drop the tank.
I also stock the Racetronix pumps if you are in need of one.
if you have a trap door above the fuel tank, do you still have to drop the tank to remove the stock regulator?
also, if replacing the stock in-tank regulator with an aftermarket one after the fuel rails, is there any wiring required or is it all mechanical? thanks!
