45lbs,65lbs, or 85lbs injectors
Old Mar 12, 2008 | 06:45 PM
bottlefed01z28's Avatar
Default 45lbs,65lbs, or 85lbs injectors
ok i did the whole injector sizing and it says im gonna need 45lb injectors when i run on just my motor only and when i run my nitrous at only half it says i need 65lb injectors, which should i run cause i will rarely run nitrous but i WILL use it. And if i run the nitrous at full open i will need 85 lb injectors that i probaly will never use. what should i get and where do i go to buy them?
im leaning on the side of 65lb just cause i know i will be using some of the nitrous but will those knjectors be to big to run just driving around.....let me claraify i like to drive the car to the races and some times i have to drive 35 mins to get there and i might not even need to use the nitrous
Old Mar 12, 2008 | 11:45 PM
wannabess's Avatar
Just use a wet kit and you will only need enough injector for NA power, extra fuel will be provided by the fuel side of the kit.
Old Mar 13, 2008 | 07:16 AM
i am using a wet kit sorry im a retard but wheres the best place to find 45lb injectors that will work with the stock computer, naturally i will have it tuned.
Old Mar 13, 2008 | 08:21 AM
wannabess's Avatar
I got my 42lb from racetronix. They will be higher lb/hr injectors on your car b/c of the higher fuel pressure.
