Question about using 30lb ford injectors in ls1
Old Mar 18, 2008 | 01:12 AM
bigfatls6's Avatar
Default Question about using 30lb ford injectors in ls1
I have heard these are the same as using 36lb injectors in an ls1. Is this true? I also have a crane/vinci tuner how do you figure the increase in size in %?
Old Mar 20, 2008 | 11:05 AM
seawolf18's Avatar
It is true, do to chevy having a higher fuel pressure than what the injectors were flow rated at.
Old Mar 20, 2008 | 12:23 PM
rob c's Avatar
Great! So I can use them with my AFR head swap?
