Fuel Pump Recomendations (turbo)
Old Mar 19, 2008 | 11:16 AM
chopperloco's Avatar
Default Fuel Pump Recomendations (turbo)
I'm building a mostly drag C5.LQ4 based 364",single T76-hope to make a 600-700 rwhp.I have completely eliminated the original fuel system.It will have external fuel cell etc...No factory components-Any thoughts?
No luck in the fuel section...
Thanks-Dominic
Old Mar 19, 2008 | 02:43 PM
Derek @ EDO's Avatar
I am building a similar setup on my truck.
Here are the fueling specs.
MagnaFuel MP-4303
-8 feed
-6 return
15 Gal. RCI cell w/ 90ohm Sender.
Billet rails on a VIC jr intake.
large fuel cooler on the return line.
Versafueler injector driver
96lb injectors
Boost Ref. EFI reg.
Old Mar 20, 2008 | 05:06 PM
Default Thanks...
... any other recomendations?
Old Mar 21, 2008 | 05:15 PM
SuperZ's Avatar
Dont do a inline for only 600-700 rwhp.You could do a single 255 intank or two 255 intanks and have one boost referenced.
Old Mar 21, 2008 | 07:00 PM
Slowhawk's Avatar
LS1Tech Sponsor
A Magnafuel like above or 2 Weldon 400'2 or 2 420L's.For a cell you'll need the external.
Old Mar 22, 2008 | 08:16 AM
stevieturbo's Avatar
Or build a fuel cell that holds an in-tank.
