Walbros
Old Mar 28, 2008 | 10:53 AM
Justg's Avatar
Default Walbros
I've gone through three walbro pumps in less than two years. The las one I made sure the pump sat at the bottom of the tank and I never let the fuel get lower than 1/4. Is there a pump that last.G
Old Mar 28, 2008 | 04:07 PM
Old Geezer's Avatar
"Walbros" off of E-bag??
Old Mar 28, 2008 | 07:52 PM
Lonnies Performance's Avatar
LS1TECH Sponsor
If you went through 3 pumps in under 2 years, something else is wrong.
Bad connections, voltage problems & undersized wiring can cause pump failures as well.
Are you using a new fuel sock with the new pumps?
I've used hundreds of Walbro pumps & have yet to have a pump failure.
I'm not saying failures are not possible, but usually there is a reason, & with 3 failures, I would be looking for the cause.
Also remember that Ebay has some counterfeit pumps out there, so beware of what you are buying.
Old Mar 29, 2008 | 01:07 AM
Justg's Avatar
pumps came from summit racing. They were the granitalle ones. I used new socks and I have a hot wire kit. I have a KB boost pump on this one. The part number on them was F2000169 if that helps. I did the install just like the sticky above.
