New style 30lb injectors
The Ford SVO red top injector is being discontinued , and we just got the new style in that is replacing it .
Priced at $269 per set of (8)
Flowmatched set of (8) $309
These are the new 30lb high impedence fuel injectors , they are replacing the Ford SVO 30lb injectors which will be discontinued . These new injectors have less internal components and do not run as hot which makes them a faster more accurate fuel injector . These are approximately 36lb in an ls1 with 58 psi rail pressure .
