pro charging fuel pump question
I haven't built my fuel tank yet, but am inclined to use an in tank setup to avoid the noise of an external pump. Anybody have any ideas on this?
here's a link to the build...
https://ls1tech.com/forums/showthrea...00#post9054000
Nate
http://www.lonniesperformance.com/
If your planning on over 500whp you better do a duel intank system with some 60lb injectors. But if i had money and could do it right i would do lonnies duel intank 255s with his kit and some 85lb injectors with the AEM converter. But if your just going with 7-8 lb of boost get the racetronix kit.
http://www.racetronix.com/RX-F98-FPKG-2.html
Its what i have and it works fine.. Easy install and its cheap.
BOSS APPROVED!
