injector question. Sizing?
Old Apr 6, 2008 | 12:30 AM
Cole Train's Avatar
Default injector question. Sizing?
ok i've just did a build on my Vette. I did a Z06 heads, 228R TSP cam, headers, LS6 intake. I still am running the stock injectors will be taking the car to the tune shop this next week EARLY. What size you think i should run or do you think i can get by with 28's~Cole~
Old Apr 6, 2008 | 12:34 AM
LT1-DAN's Avatar
Do you have any future plans of getting more power out of the engine? If not you can get by with 42s.
Old Apr 6, 2008 | 12:42 AM
Cole Train's Avatar
no, engine will be good for a while lol
Old Apr 6, 2008 | 12:56 AM
LT1-DAN's Avatar
42s will be more than enough.
Old Apr 6, 2008 | 01:52 PM
Robert56's Avatar
Check my web for sizing math and rerscaling injectors.
Robert
Old Apr 6, 2008 | 09:29 PM
ZL1Killa's Avatar
or CHECK THE STICKY here on the FUEL AND INJECTION THREAD.... i don't want to seem like an *** but it is at the top of this topic..
42's will do ya fine
Old Apr 6, 2008 | 10:09 PM
405HP_Z06's Avatar
You could stay with the stock 28.8 lb injectors but my guess is you will be over the recommended 80% duty cycle in the top end. If the car is going to stay at the current power level for some time, I would recommend the Ford red top injectors (30 lbs/hr @ 3 Bar) or the FAST 303608 (36 lbs/hr @3 Bar, 41 lbs/hr @ 4 Bar). I personally like the FAST injectors because these are the injectors used by GM in the ASA engines and the PCM calibration tables are readily available.
Old Apr 7, 2008 | 02:02 PM
Cole Train's Avatar
i picked up some Lucas 42's last night. Thanks for the info guys. I hope they work ok. I was thinking i may get by with the stockers but i just don't want to risk getting to the tune shop and then having them max out~Cole~
Old Apr 8, 2008 | 07:43 PM
ZL1Killa's Avatar
yeh man, i hear ya ... i would hate for ya to dyno low or have to get out of it cuz your running out of fuel 42#ers will do ya to 500HP easily
Old Apr 8, 2008 | 09:58 PM
Cole Train's Avatar
They SHOULD be here tomorrow(wednesday) so i'll see when they get here~Cole~
Old Apr 10, 2008 | 07:18 PM
Robert56's Avatar
You should be able to get more hp than 500 out of em, though. My numbers in sig are with Ford 42 green tops, however, they become about 47lb'ers at our fuel pressure.
Robert
Old Apr 11, 2008 | 12:01 AM
ZL1Killa's Avatar
yeh, 42#ers will do ya for a good bit. i just knew they would do 500 hp no problem
