this is the best place i could find to ask this.
Old Apr 7, 2008 | 10:09 PM
lt1noob's Avatar
Default this is the best place i could find to ask this.
ok, so ive heard before that certain cars you cant run 93 octane in because you will get a knock. but some cars adjust and fix the knock. now the question is, will i be able to run 93 octane without any problems with a stock ecu in a 95 firebird? i beleive i can but i would like to make sure before i fill up a whole tank >.<...
Old Apr 7, 2008 | 11:01 PM
lt1noob's Avatar
anyone ?
Old Apr 7, 2008 | 11:05 PM
white99's Avatar
One way to tell is to run 93 while data logging. Check the log for knock
Old Apr 7, 2008 | 11:06 PM
Soul TKR's Avatar
i've heard of having low octane causing a knock... but higher?
Old Apr 8, 2008 | 11:33 AM
lt1noob's Avatar
yes higher can, but, so this means i can run 93 once my car gets here? thats all i need to know.
Old Apr 8, 2008 | 11:34 AM
lt1noob's Avatar
just need to know once i fill up if i can use 93 and not have a problem. because i know it burns slightly cleaner and burns slower, and ill get abit more power. sounds worth the slightly higher price.
Old Apr 8, 2008 | 03:21 PM
MeentSS02's Avatar
Kleeborp the Moderator™
I would run 93 without a question...it is a high performance engine, and shouldn't have a problem.
Old Apr 8, 2008 | 05:43 PM
lt1noob's Avatar
good good, thats what i wanted to hear thanks a ton.
