Fuel pressure dropping on new gauge
because the fuel pressure regulator is in the tank and not on the engine, the system has more delay from the time fuel demand rises till the regulator can close up and bring the pressure back up to where it should be.....its not a problem.....
my guess is the regulator, maybe it would be worth while for you to go to an aftermarket one.
although mine supported my 512+rwhp
so it souds like your regulator is crapping out.
58 dropping to 40 at idle, just popping it is bad.
Something is wrong.
I bet it will go below 30 at WOT, have you watched it?
Any drops of more than 5psi from 58psi is not really good.
if the intank cant pump fuel to the inline, well no fuel.
