Question on Fuel setup?
Old Apr 13, 2008 | 08:35 PM
nvmy2000ss's Avatar
Default Question on Fuel setup?
I am wondering if using a twin intank with stock feed and evap as a return will support 700rwhp (f/i)? Also for those of you that run -8 from the tank do you modify the bucket and use a 90* bulkhead out of the top? Anyone have any pics of this? ultimatly this is what I would like to do but there is quite a bit more expence involved.
If I were to run a -8 to the rials would I need to change my crossover as well (I believe this is -6) Im assuming that upgrading the feed would be pointless if the crossover was still a -6.
Thanks
Old Apr 14, 2008 | 09:30 AM
nvmy2000ss's Avatar
Can someone help me out?
Old Apr 14, 2008 | 10:23 AM
Nasty N8's Avatar
Yes with dual pumps you can support 700rwhp and no need for the bulkhead the stock fitting flows just fine. Good idea to upgrade the fuel lines at the same time and you will need to add a -8 crossover to be effective.
Nate
