42lb or 60lb injectors
what about rceng.com's injectors? you can get them flowmatched too
you can grab you some :
http://www.rceng.com/Peak-Hold-Injec...550-P17C5.aspx
50#ers so you won't idle rich
NOW one thing i do not know is whether we need peak and hold injectors or saturated injectors... that you could probably also ask RCENG
Based on my calculations and worst case, at 700HP (BHP) on RCENG website you would need 60lb/hr injectors MAX to achieve 80% duty cycle
somewhere between 52# and 56#/hr injectors is what you need RATED at 43.5psi
an injector rated at 58psi (or 60psi) yielding a 60lb/hr rating would do you fine
