installing racetronix...2 quick questions
Old Apr 15, 2008 | 07:10 PM
Travis99LS1's Avatar
Default installing racetronix...2 quick questions
hey whats up everybody..this weekend i'm gonna be installing my nitrous kit, and my racetronix fuel pump..I'm gonna be cutting an access panel instead of dropping the tank, i've searched on how to do it and found a good write up on how to do it on an LT1..is the fuel pump in the same spot on an LT1 as it is on a 99 LS1?? the write up i found has all the dimensions on where to measure and cut, but i just want to make sure before i start cutting that its in the same spot...My second question is after i install my fuel pump am i going to need to get my car re-tuned or is my a/f ratio gonna remain the same? Alright well i know these sound like pretty dumb questions but i just want to make sure i have my basis covered before i start the install this weekend..I cant wait to get this kit installed and start spraying ..alright well thanks for any help you guys can give me.
-Travis
Old Apr 16, 2008 | 12:53 PM
Nasty N8's Avatar
Racetronix HIGHLY rec. dropping the tank because you need to clean it out as the debree in the bottom of your tank will kill your new pump in no time.
Nate
Old Apr 16, 2008 | 04:42 PM
hey i'm not gonna drop the tank so do you know if the pump is in the same location as the LT1? I appreciate the reply..i feel if there was that much crap in the bottom of my tank, my stock pump would have died by now..
Old Apr 16, 2008 | 08:26 PM
koolaid_kid's Avatar
No, it is not in the same location as the LT1, although the work is the same. Find one specific for the LS1. I don't have a link for it (since I have an LT1) but I have seen the writeups and the location is different.
Dropping the tank is recommended, but not required.
No tune is required, AFR is not affected.
Best of luck.
Old Apr 16, 2008 | 11:00 PM
Nads06111's Avatar
where is it on the LT1?
Old Apr 16, 2008 | 11:05 PM
NBM99SS's Avatar
How are you going to run the hotwire kit if you dont drop the tank? It wont happen
Old Apr 16, 2008 | 11:07 PM
SS1875's Avatar
Default Install
http://www.gonicd.com/intankinstall/...mpinstall.html
Found this...hope it helps you out.
Old Apr 17, 2008 | 03:53 AM
Sure it will. Did mine that way, absolutely no problems. Most of the kit is under the car, not in or on the tank.
Old Apr 17, 2008 | 04:53 PM
i appreciate the help guys
