Fuel pressure dropping off walbro pump
Old Apr 21, 2008 | 08:21 AM
Badls6SS's Avatar
Default Fuel pressure dropping off walbro pump
I have a walbro f/p 255lph in my 98 camaro. I installed my own f/p wire kit directly feed from the alt. When i start my car up cold the pressure is @ 57-59 psi While the car runs it slowly drops off down to the 20's it will then fall futher and finally stall. It will restart but it takes awhile and the pressure is still low. Has anyone else come across this the pump is only 2 years old.
Old Apr 21, 2008 | 08:50 AM
WHPLASH's Avatar
Mine is doing something similar too. When the car is running, its at 62 psi. When I give it the slightest amount of gas it drops to 57-58. If I give it more, it'll drop below 50 psi.
Not good my friend. My car goes in next week to get it fixed.
