fuel rails. help!
Old Apr 27, 2008 | 12:49 AM
94TRANS's Avatar
Default fuel rails. help!
do i need a "return" or "returnless" fuel rail kit for my car? 99 Z28 A4, all mods in sig if that helps other than that its all stock, am getting new fuel rails for the new LS6 intake going on and need to know. thanks for any help.
-Kris
Old Apr 27, 2008 | 01:24 PM
94TRANS's Avatar
BUMP i need to know, dont want to order the wrong thing.
Old Apr 27, 2008 | 04:11 PM
Big-K-Performance's Avatar
I would say that the stock returnless rail would work for you, but if you plan on building more horsepower in the future you may want to upgrade. I was making 400 rwhp on the stock returnless rail, pump and injectors and all was fine.
Old Apr 27, 2008 | 04:40 PM
MeentSS02's Avatar
Kleeborp the Moderator™
Returnless unless you really want to do a full fuel system overhaul.
Old Apr 28, 2008 | 08:58 AM
nastysupaspt's Avatar
I did research with my set up heads and cam and aps tt kit running 7psi should put me high fives and my stock lines and fuel rails will be fine. all my fuel set up will consist of is 60lb injectors and twin pumps intank
Old Apr 28, 2008 | 11:53 AM
Nasty N8's Avatar
You can use your stock rails with the intake but if you wanted a different look we have a kit to install our rails(or any rails) into your factory setup.
Nate
Old Apr 28, 2008 | 02:17 PM
94TRANS's Avatar
alright thanks guys, i didnt want to order the wrong thing.
