Fuel Pump or FPR?
I have recently finished a custom rear mount build and put in a walbro 255 in the process I have 65lb/hr injectors that I am NOT running yet but I was putting some test miles on the new setup before I went to get it tuned and on the way home I was getting a little low on gas, well I did a California stop at an intersection and when I was rolling away in second gear (1/8th throttle) I noticed a sputter and and it was on and off for about a 1/2 mile to my house (had been driving the car problem free for about 3 hrs) got home cut the car off .. wont crank back .. acted out of gas so I went and got some. Got a half tank now fuel pump comes on when I turn the key over, got a fuel pressure gauge today and I see 10psi on the rail when turning the key over and about 16 when trying to crank. What should I check replace first (I still have my old pump and I used the access door method
) I hope you bought a good kit with factory style flex hoses & a venturi setup.
Does it hold pressure with the key off, or does it drop quickly?
This can determine if it is a leak.
It is rarely the regulator unless you got dirt in the line putting it back together.
Nate
