Fuel return
Old May 5, 2008 | 03:43 AM
flippincamaro's Avatar
Default Fuel return
I turboed my 98 z28 and am wanting to do a return style fuel system on it. Where would I run the return to the tank too? Is there a spot on the top of the pump I can run the return to? Any pics thanks guys for any help
Old May 5, 2008 | 10:15 AM
Nasty N8's Avatar
Yes the pump assembly has a return line in and a feed line out fitting. I can get you the correct fittings or put together a complete system for your needs if you like give me a call I will help you out.
Nate
