Racetronixs
Old May 5, 2008 | 08:21 PM
94m6Z28's Avatar
Default Racetronixs
got my racetronixs kit today. not bad
put the injectors in, 42's flow matched disc styles or what ever they are
for starters. the factory c clip thigns on the rails dont work. the slit on the injector is only on the sides that face eachother then wehn installed it.. they seems to fit looser in the rail - intake space and the eltornic connectors seem to fit tighter....am i going to have problems with leaks and what not???
Old May 5, 2008 | 10:35 PM
405HP_Z06's Avatar
As long as you bolt the fuel rails down to the intake you won't have any issues. The c-clip issue is common and not really needed. I surmise it's there from the factory to keep the injectors in the rails during installation.
Lube the o-rings enough to allow the injectors to easily slide into the rail and you won't have any issues.
Old May 5, 2008 | 10:37 PM
94m6Z28's Avatar
lots of lube used on both ends... now to install the rest and get the rest of my turbo goodies and im off
