Any place to send injectors to have them tested??
Old May 5, 2008 | 10:25 PM
SupermanSS's Avatar
Default Any place to send injectors to have them tested??
Have 42lb SVO injectors that I want to swap into my SS but need to test them to make sure they work first. Anywhere I can send them off to?
Old May 5, 2008 | 10:30 PM
405HP_Z06's Avatar
Many places, http://www.witchhunter.com and http://www.cruzinperformance.com are both very reputable and reliable companies.
Old May 6, 2008 | 10:53 AM
Nasty N8's Avatar
http://www.neweraperformanceparts.com/ they are a sponsor on here and do very good work. Dealt with them many times.
Nate
Old May 6, 2008 | 03:39 PM
ZL1Killa's Avatar
or hook them up to your fuel rail with it off the car, hook up a air hose and tank and ever so lightly pressurize the fuel rail. then use a 12V battery and tap the two prongs on each injector. if they hiss at you they work
Old May 6, 2008 | 03:56 PM
LT1-DAN's Avatar
RC Engineering does it all also. I had them clean/balance a set of injectors for my 96 Vette a couple years ago. They did a great job.
