How to setup Aux pump?
Old May 16, 2008 | 05:28 AM
johnnyddn's Avatar
Default How to setup Aux pump?
I'm going to install a Weldon external fuel pump. Instead of getting a pump controller I thought about using the an internal fuel pump and setting the weldon up to turn on at a certain RPM or boost setting. My question is how to setup the fuel lines to run an internal and external pump. Should I just use a T-connection from the internal pumps fuel line to the Weldon's fuel line going to the fuel rail? And if I did how would I make sure the internal pump isn't just pumping fuel in a loop back into the tank?
