Bad injector?????
Check across the pins on the inj, with a VOM. See if the coil is showing "open". If not open, get the ohm reading. If it's OK, then swap the inj to another cyl, and see if the problem follows.
Have you done a leakdown, or compression test?
grab you an air tank and a 12V battery. hook up the air tank to your fuel rail, and slightly turn the air tank open and then run your leads on the battery to each injector and ones that don't hiss at you are bad
