Fuel PSI Issue
8AN feed from a Magnafueler pump capable of supporting 1000hp NA and 800 hp FI. I'm running boost referenced Aeromotive fuel PSI regulator, utilizing factory 6AN for return.
The Problem:
At around 5400rpm the car falls on her face. Fuel PSI drops to, or drops 25 PSI. My fuel PSI regulator is mounted behind the drivers headlight. I have single 8AN feed to 1 rail, looped at the back, out the other rail to the PSI regulator. All lines appear good, no kinks etc.
Any idea why this would happen? Faulty regulator?
Any help appreciated.
How is your fuel pickup installed in the tank & what size?
I have good luck with Magnafuel regulators, so that should not be your problem.
What size injectors & how much power?
Chad,
Is the dual pump one of my setups? If so call me.... mine will support a good 400hp more than you are making. What lines are youy using? What wiring?
Let me know, I'll try to help.
The Problem:
With a F1 pullied up, you may be at the limits of the 4301 pump, i use a 4303 pump on anything over 700hp. Hell i have a caddilac here with 810hp and it has a 4303 pump , the customer does not mind the pump.
Here is my thread about my problem. Feel free to jump in and put your input into it. I would appreciate your thoughts on my setup.
https://ls1tech.com/forums/fueling-injection/923815-what-deal-here-walbro-pumps-bad-after-only-5k-miles.html
Nate
I bought the setup from you. I told you what I was building and asked for a system to support 800RWHP, infact I bought 2 setups, 1 was sent with a Weldon 600A, the second came with the Magnafueler. I am 10AN to the pump from the tank, 8an to the rails, 6an return. I've seen many similar setups and all worked well... I'm just the "bad luck boy". I hope the Tuner can find out exactly what is going on. I would think that my injectors are plenty big, and the 4301 big enough to support 800rwhp..... I guess I'll find out soon enough. Nate if you have any other suggestions that I am not thinking about, please PM me and give me some knowledge. I appreciate everyones' help and opinions.
Nate
