How much injector do i need?
Old May 22, 2008 | 12:05 AM
chevyguy7802's Avatar
Default How much injector do i need?
Whats up guys....
Im from the truck site....im currently in the process of swapping an Iron
block ls1 into my 78 chevy c-10....im getting closer to buying all the parts for
fueling the motor before i get her dropped in here are some specs of the motor to help out.....and I will be running 200 wet shot of nitrous(2 stage)
5.3 block punched out to a 5.7
11:1 compression
226/230 .584/.591 112+4 custom grind comp cam
Prc stage 2.5 5.3 heads
Ls6 intake
Im just trying to figure out what size injector im gonna need and if i should go with the return style fuel rails or not?
Any help will be greatly appreciated!
Old May 22, 2008 | 06:35 AM
ZL1Killa's Avatar
check out my fuel and injection sticky that explains injectors.
I reckon around a 42# injector would be fine as you are running a wet nitrous kit.
Old May 22, 2008 | 03:45 PM
Thanks for the reply.......I was thinking the 42 # would be the one to go with I just needed to hear somebody else say it!
