Best pump & injectors 600hp
Old May 26, 2008 | 12:19 PM
white00ta's Avatar
Default Best pump & injectors 600hp
I'm looking for the best pump and injectors for 600 hp. I should be running right around 430hp n/a. With juice i should be around 550-600hp.
Old May 26, 2008 | 01:09 PM
405HP_Z06's Avatar
For the fuel pump, Lonnies Performance has great fuel systems, look>>>>>>>>
http://www.lonniesperformance.com/
For fuel injectors FAST 36lb (Part # 303608) or Racetronix 42lb. The 36lb will easily feed this HP level with room to grow, the 42lb will give you a lot of room to grow.
Old May 28, 2008 | 10:15 PM
98BlkFormula's Avatar
really from what i have heard they max out at around 500hp
Old May 28, 2008 | 10:39 PM
Sideways240sx's Avatar
racetronix hot wire kit is what i would suggest for the pump, but a 255 walbro will work fine for those numbers. 36 pound injectors should be ok. 42's not needed, but if it were me id rather upsize, and only buy them 1 time. As far as your shot goes, is it wet? if so then the solenoid/nozzel is providing extra gas not the injectors. That will affect your pump but not injectors.
Chris
