Submerging braided line
Old May 27, 2008 | 09:52 AM
veee8's Avatar
Default Submerging braided line
Is it OK to submerge braided line in the tank for plumbing 3 Walbros? Specifically with E85? I know the inside of the line is ok, but what about the outer casing?
Old May 27, 2008 | 06:24 PM
Jake@EPP's Avatar
You might consider a teflon type hose due to being in 85% ethanol. Earls has a proflex version of the teflon line and hardcoat anodized fittings.
Old May 27, 2008 | 08:31 PM
veee8's Avatar
Kind of what I was thinking, thats the black stuff right? Proflex?
Old May 27, 2008 | 09:19 PM
CTSmechanic's Avatar
You can submerge braided line I have ran it in fuel cells for quite a while its all in what you wana spend...
Old May 27, 2008 | 09:24 PM
Jake@EPP's Avatar
They have the new stuff its either the black braid or the normal stainles. But the diff is the inside core is no longer rubber , but its teflon. I think its called proflex 750. Its a bit more expensive then the normal hose, but its worth it for safty with alky.
Old May 27, 2008 | 09:45 PM
veee8's Avatar
Probably only need a foot or so in the tank. Plumbing 3 intank walbros.
