What do I need?
Old May 28, 2008 | 08:40 PM
camaroIroc's Avatar
Default What do I need?
Im running a budget build with a 99' 5.3 truck engine in an 86' Iroc....using truck harness and computer. The fuel system is something Im having issues with, I dont know exactly what I need.
Is this all:
Fuel pump
Fuel lines
Fuel filter
tank
Regulator
58psi
Any help is appreciated.
If you guys know some good brands for a real good price feel free to post them too. Im an ebay maniac...
Old Jun 1, 2008 | 09:37 PM
ZL1Killa's Avatar
injectors... probably 32# would be fine
Old Jun 1, 2008 | 09:52 PM
nuckifuts's Avatar
you can use your stock tank, just put a high pressure walbro 255 pump in the stock ones place (assuming your iroc is TPI). i use a 2000 or so vette fuel filter, -6 lines. look in the conversions section, its all over the place on how to do it.
good luck.
Old Jun 2, 2008 | 07:21 AM
ZL1Killa's Avatar
yep. Nasty N8 can hook you up too. grab you a 255Lph fuel pump and new injectors and you will be set
