newbie question
Old May 29, 2008 | 02:45 PM
shdybrady1988's Avatar
Default newbie question
Can you go overboard on a fuel system? With the mods I have now can I go ahead and install a large set of injectors and fuel pump and it run alright with a tune? Or should it be the last thing you do? I am a complete newb when it coes to the fuel system so any info will help.
Old May 29, 2008 | 03:27 PM
ZL1Killa's Avatar
YES you can go too big on fuel injectors
talk to Nasty N8 up here
you can make up to 500HP(rear wheel) and be on 42# injectors and they will also run fine on a stock car
DO NOT, PLEASE DO NOT BUY ANY 60# injector
check out my sticky on the fuel and injection page linky below:
https://ls1tech.com/forums/fueling-injection/293742-fuel-injector-size-calculator-fuel-pump-chart.html
ALSO, from Rceng website:
http://www.rceng.com/technical.aspx
ask me any questions about that and I can tell you how to fill it in and get you situated with what you need
Old May 29, 2008 | 03:31 PM
thanks alot man. And what fuel pump and filter would you pair up with 42# injectors
Old May 29, 2008 | 03:50 PM
ZL1Killa's Avatar
well what power are you looking at eventually making?
I'm seriously never going above 550HP (Rear wheel) so I just grabbed the racetronix PnP kit with their 42# injectors. its the same as a 255Lph pump and it also has the option of running the BAP(boost a pump) which gives more voltage to it
Old May 29, 2008 | 04:16 PM
i probably have similar goals. I use to say i wanted 600-700 at the rear. But then i started to learn how much it takes to really get there. With out a power adder you have to be hair shy of being and engineer to make that happen, unless you have the money to pay someone else to do it. I might add a procharger one day but for now I'll be sticking n/a. How much did that kit run you?
