Gas Fumes!
Obviously I've done a ton of fuel work for my blower. Walbro intank, -6AN fuel lines, Speed Inc. fuel rails, Aeromotive boost referenced FPR.
I cut a hole for access to the tank. I cover it with steel metal, RTV sealant, and sheet metal screws(very tiny ones) to secure and seal. I would think, if it were the bulkhead seal on the top of the tank that the interior of the car would reek of gas even if it's parked outside. But that's not what happens. The interior only smells if the car is in a garage(and that's cause everything smells like gas). Maybe the RTV is enough, cause the tank seems like the obvious thing to look at first.
I guess hat I'm asking is how do I figure out where the gas is coming from?
Thanks guys,
Mike
Right now, and pretty much since I've redone the fuel system, I have been running without cats. I'm eventually gonna upgrade my fuel lines and fuel filter. At that time I guess I can double check each and every connection.
I was afraid that it was the top of the tank leaking. But one thing I notice is that the longer the car sits the longer it takes tyo start it up the next time. I thought it was just that my FPR was leaking fuel back into the return line.
Thanks for the suggestions, I'll give these a try.
Mike
