balancing of fuel injectors
Old Aug 12, 2003 | 09:29 AM
grangor's Avatar
Default balancing of fuel injectors
Why do your injectors need to be balanced? I thought your injectors where controled by the settings in little black box?
Old Aug 12, 2003 | 12:09 PM
red ws6 99's Avatar
Default Re: balancing of fuel injectors
Injector balancing insures that all the injectors are within a few percent of each other (flow rate wise). So basically you get 8 reasonably matched injectors. That way one cylinder or whatever that is significantly different than the others. Makes tuning much easier and safer.
Gary
