Fuel problem line problem..
Old Jun 13, 2008 | 10:28 PM
Sideways240sx's Avatar
Default Fuel problem line problem..
Well i just got done putting my turbo back on my ls1. Didn't touch the fuel lines since winter when i swaped in injectors, and put 1200+ miles on it, and tuned never had a leak. Now tonight get it all together, and turn it on, and the factory line that feeds the driver side rail is spraying/leaking lots of gas.
Very wierd something wore out, or broke, but im sure im not the first person this has happened to? so whats the best way to fix this?
Do you need some special tool to pop this line off? I may try running to autozone in the morning and seeing if i can find anything, just wondering if any one has any other thoughts.
Thanks, chris
Old Jun 14, 2008 | 09:11 AM
Broke EF's Avatar
Nothin huh
Sean
Old Jun 14, 2008 | 06:18 PM
OUTLAWZ RACING's Avatar
Thanks, chris
There is a special tool auto zone has it but its cheap The one adavance auto sales is black and built better same price
Old Jun 14, 2008 | 11:13 PM
I may pick one up. I ended up getting the line off with a hose clamp i cut, and folded over in a circle to pop the clip off. Both of the o rings had little rips in them. So i will replace them. Thanks.
Chris
