Running shorter injectors.
Old Jun 15, 2008 | 10:57 PM
WS6HUMMER's Avatar
Default Running shorter injectors.
I just tried installing my seimens deka 55# injectors and they fit but are about 1/4" shorter. Did some searching and cant find anything on this probelm, just wanted to post up and see if there was a easy fix before I cut and reweld the tabs up higher.
Old Jun 16, 2008 | 09:34 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
The best fix would be to sell them to someone who needs the shorty injectors, such as ls2 or truck owners, and buy the standard long 60# injectors. You could probably get a even swap pretty easily. Shortening the rail spacing isn't any easy feat.
Old Jun 17, 2008 | 02:52 PM
ZL1Killa's Avatar
im with him
Old Jun 17, 2008 | 04:30 PM
WS6HUMMER's Avatar
Originally Posted by ZL1Killa
im with him
Thank you guys. I got it taken care of.
Old Jun 18, 2008 | 09:00 AM
ZL1Killa's Avatar
a curiosity question ... how much power are you making or going to be making. I noticed you are playing with the 55# and 60# injectors
Old Jun 18, 2008 | 09:04 AM
WS6HUMMER's Avatar
700+ to the wheels, 76mm Garrett & 317 heads. Plus I would like to eventually run E85 and I dont even know if the 55's will be enough for that.
