Fuel Pump: drop tank or make access door?
I've been having fuel issues and my tuner can't tune my car to it's potential until i get more fuel. So i'm going to swap the fuel pump and probably the fuel filter again just in case. I don't know if there is much more i can do. is it easier to take out the back seat and cut through the metal to access it from the top or should i just drop the tank? is there a write up on how to make an access point for the fuel pump?
Dropping the tank is a pain, but I recommend it. It gives you a chance to inspect everything and clean out the tank. If anything happens after that (like you need to replace the pump again, issues w/ it, anything) you can always cut the hole so you dont have to drop it again.
Heres the link that should have everything you need to know about the access hole. If you need more just search "Trap Door"
https://ls1tech.com/forums/showthrea...swap+pump+fuel
Heres a writeup I did earlier this week about dropping the tank. It will show you exactly what you need to do to drop the tank. Good luck.
https://ls1tech.com/forums/fueling-injection/938621-fuel-pump-dropping-tank-write-up.html
Cut it and take your time to make it look nice. Alot of cars come factory with access doors. We mod our cars to make them better,being able to service your fuel pump and sender in 10 mins is better than 4hours.
i dropped the tank and put in my new walbro pump. drove the car for 50 miles and then it wouldn't start. had it towed home. i dropped the tank AGAIN! figuring that the fuel hose had blown off, but everything looks fine. what can i do?
CUT IT!!! the carpet covers it anyway...Im pretty **** about my car but no one will ever know I cut it unless I show them....most give props and how smart that was and how easy it is to get the pump.
Cut the access door and dont look back (3 times as fast and make life easier just incase you have to get to it again) because I wished I could have done the Camaro and Trans Ams I had to drop the tank at the dealership when I worked there a few years ago. Good Luck
