Smell fuel from inside car and overflow?
Old Jun 19, 2008 | 08:12 AM
Superman09's Avatar
LS1Tech Sponsor
Default Smell fuel from inside car and overflow?
Got my car yesterday and when i filled it up, i noticed i could smell fuel like i was at the gas station still for quite some time inside the car! As the tank got lower the smell went away. However when i filled up again, just before the nossel clicked on the pump i heard a splash... Sure enough under my car was gas. It leaked out where my bucket seals to the top of the tank... This would explain why i could smell fuel also. Isnt this supposed to be air tight? What might have gone wrong there and/or be missing? Thanks!
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old Jun 19, 2008 | 08:56 AM
Old Geezer's Avatar
Someone has been into the tank.. fuel pump change, etc.
The seal is fubar.
Old Jun 19, 2008 | 09:30 AM
Superman09's Avatar
LS1Tech Sponsor
yea, dual pumps were just installed. Should i replace the o-ring, or use RTV instead, or use both?
__________________
Old Jun 19, 2008 | 09:38 AM
Old Geezer's Avatar
Exclamation Do Not
use silicone as a seal for a fuel system. It can/will turn to "snot", and make a serious mess.
Replace the o'ring.
Old Oct 11, 2011 | 08:47 PM
TIIMuch's Avatar
EXACTLY what my car did after changing the fuel pump in a LT1 Camaro.
fuel/gas would overflow under the car when I reached full at the gas station and then would leak out from under the car whenever I created any G forces with the tank full.
I would leave a trail of gas and have a strong smell in the car(I still had'nt sealed my trap door).
I found the seal not sitting fully around.
F**k,...without this site and the search function I would have given up on this car a year ago.
Now,...*will it ever end!?*,...new "used"fuel pump setup has fuel guage stuck on way past full,...I'm thinking I better swap the new "used" Walbro onto my old(fuel guage working fine) sending unit.
