Intermittent Cranking Problem
Old Jun 22, 2008 | 02:55 PM
mudflap1989's Avatar
Default Intermittent Cranking Problem
I have a stock 98 Z28. Sometimes it will crank right up and sometimes it will just turn over and turn over and not start-up, then 30 minutes later it will start up. The problem is that it doesn't get any fuel because I can spray starting fluid in it and it will start up and then die. I can hear the fuel pump running, but I haven't tested the fuel pressure.
I have HP tuners, but I have almost no idea how to use it, but my injectors are firing according to HP Tuners. Does anybody have any ideas what it might be???
Old Jun 29, 2008 | 12:37 PM
Carter01's Avatar
If the car will crank sometimes and not others than the spark should be ok. I would then lean to the fuel side. Start with the basics like a new fuel filter. If that doen't help then when you do get it to crank be prepared to do a fuel pressure test while driving under a load. Which if your pump is close to going out it may show itself without doing the driving test. However I would stay away from the "spraying starter fluid" in the engine trick. Eliminate one thing at the time and you will find the source.
