Keep blowing fuel pump fuse?
Old Jun 23, 2008 | 01:36 AM
TransAmcoupe98's Avatar
Default Keep blowing fuel pump fuse?
Was on the way to the dyno the other day and the car just stalled. Was able to coast it into a parking lot and saw that the fuel pump fuse was blown. Replaced it and drive to the dyno, got there, had to wait in line, went to go start it up and it blew another one. Put a new one in again and it blew it immediatley. Keep in mind that my STS kit is new on my car and I just got the fuel pump. Granetelli 255lph. It sounds kinda like the pump but since the STS oil pump also works off the fuel pump relay, could it be that the STS oil pump is dead?
Old Jun 29, 2008 | 08:33 AM
fuseone's Avatar
gotta have a short some where in that circuit.
Old Jun 29, 2008 | 08:35 AM
thechad's Avatar
Might also try 5 amps bigger for ***** and giggles
Old Jun 29, 2008 | 09:40 AM
Old Geezer's Avatar
Question I just replied to
a thread in the conversions section. Guy had a new Granetelli 255, from Summit, go tango uniform. It was new. It got noisey, then the FP dropped.
Old Jul 1, 2008 | 09:34 AM
2000Firehawk's Avatar
CAUTION
Don't go more than 5 amps larger on any fuse, as you could start a fire, or 'melt' wires that can't handle the load...
fuses do serve a cause...
like putting a 'penny' in an old fuse box, causing a house to burn down...
If you increase the load, with more/bigger, or bad/shorting out parts, the fuse blows to save your ***....
Find/correct the problem, if there is a problem.
Or
Upgrade the circuit to handle the increase load....
