Fuel lines into the bucket
Old Jul 2, 2008 | 11:40 PM
FASTLS1WS6's Avatar
Default Fuel lines into the bucket
I just started to put the fuel bucket together. I am using twin walbros and -8an lines. If I just slide the -8an lines over the stock feed out let on the fuel bucket and use a hose clamp, will the pressure blow the line off or will it be fine?
Thanks
Old Jul 3, 2008 | 06:49 AM
MeentSS02's Avatar
Kleeborp the Moderator™
The right part is available to do what you want. You need two parts:
Aeromotive 15118
Aeromotive 15607 (this screws in to 15118, and adapts it to -8AN)
Russel also makes the proper quick disconnect (which is 3/8" for feed and return BTW), but it takes -6AN fittings instead.
Don't chance a hose clamp, especially when the right parts are available. The last thing I'd want is the line slipping off and spraying fuel everywhere because I cheaped out.
Old Jul 3, 2008 | 10:06 AM
Nasty N8's Avatar
Yes the clamp will not hold 58 psi for long you going through the hassle of upgrading the lines why not get the fittings right. I keep those fittings in stock.
Nate
Old Jul 3, 2008 | 06:53 PM
RsSean's Avatar
I am kinda new to the terms in this section. The bucket is the top of the fuel pump where the hard lines are right? Trying to upgrade to braided lines worried about the hard line out of the tank, is that is what is being talk about in this thread? Clueless.
Old Jul 3, 2008 | 08:35 PM
MeentSS02's Avatar
To me, the bucket is in the tank where the fuel pump lives, but yes, we are talking about the three hard points on the top of the tank where the factory quick disconnect fittings plug in. There are at least two companies (listed above) that make the correct fittings to adapt them to braided lines without the need for hose clamps.
Old Jul 4, 2008 | 02:15 PM
RsSean's Avatar
Good then I am in the rigth area to do so then.
