Fuel pump trouble...
Old Jul 13, 2008 | 02:14 PM
TARZAN's Avatar
Default Fuel pump trouble...
We are just in the process of putting the engine back in my car, hooking up the harness, etc...Went to fire it off today, and its doesn't continuously get fuel. Hotwire kit is hooked up, priming system works, but when you attempt to crank it....nothing. As I said, I know the fuel pump is ok and getting power, because it gets fuel during priming, but nothing after that. Is there a sensor that (if we broke during install) would keep the fuel pump from running?
Thanks,
-Will
Old Jul 15, 2008 | 10:17 AM
Nasty N8's Avatar
Crank position signal or ground strap not on?
Nate
Old Jul 16, 2008 | 06:06 PM
TARZAN's Avatar
Purchased a new CPS and have a new connector for it on the way....ground all checked out. anything else it might could be?
Thanks,
-Will
