Benefits of flowmatched injectors?
I am looking at the SVO 30lb. with the all red body(newer style).
The price on the flowmatched set is about $322 shipped to me which I think is pretty good.
I am just trying to learn a little bit, what are the advantages of having flowmatched injectors over non-flowmatched?
I appreciate the help, Thanks!
my %'s might be off but you get the idea
Flow matched injectors keep these variances to a minimum, so you should be the most accurate fueling possible. It is just one of those "every little bit helps" kinda things in my book...
When I got mine, they were all marked with a number, and the flow sheet said which ones flowed what. I put the heaviest flowing injectors in the back cylinders since they tend to run lean, and put the smaller ones up front.
What did it do for me? I have no idea...but the last time I pulled the spark plugs, they were all damn near identical to one another, so I'm happy.
