fuel pump help
Old Jul 22, 2008 | 08:10 PM
fatdave's Avatar
Default fuel pump help
OK I did a search and still cant find what I am looking for.
I just installed the wallbro pump kit from Nasty. I ended up putting a tear in the new "straw" line from the pump to the to of the assembly. I am going to replace it with a 5/16 diameter fuel injection line. Does anyone know of this being done before and if it works ok?
My second problem is with the fuel sock. When I took the stock unit apart there was a sock on the bottom of the bucket and one on the bottom of the pump. The one on the bottom of the bucket got damaged taking the thing out of the tank, and the one on the pump had to be replaced. I can not find a part number anywhere for just the sock. If there is already a sock on the bottom of the pump what does the one on the bottom of the bucket do? Would it be ok to run with just the one on there and not the other?
Any help you all could give me would be great.
Old Jul 28, 2008 | 11:08 AM
ZL1Killa's Avatar
get you a new sock. look on GM parts direct website for the sock.
Also, get in touch with Nasty N8 and he can help you
Old Jul 28, 2008 | 01:38 PM
Superado's Avatar
11 Second Truck Club
MM used FI hose in-tank w/o problems...
as long as you have a sock on the pump itself, the one on the bucket can be removed w/o issues...
Old Jul 28, 2008 | 08:51 PM
fatdave's Avatar
thanks guys I put it all back together with just the one sock on the bottom of the pump and used the fuel injection hose every thing is going great so far
