questions on twin pump install
Old Jul 28, 2008 | 10:41 PM
rubbersdown's Avatar
Default questions on twin pump install
I read the sticky and it sounds super easy only thing I cant figure out is to install twin pumps you have to take off the "bucket". Well the fuel level sensor float is attached to the bucket. So where do you attach the float now? I cant tell by the pics and I didnt see where it said.
Old Jul 31, 2008 | 09:44 PM
Shoaf85's Avatar
I will be doing this very soon and from my understanding the bucket is put back on the pump assembly. It is removed only for modification and then re-installed!
Old Jul 31, 2008 | 09:57 PM
Will both pumps fit in the bucket? the pics do not show him put the bucket back on in the sticky and the float is not attatched to it either.
Old Jul 31, 2008 | 11:09 PM
AFASTYZFR1's Avatar
you might have to cut the bucket some to get them to fit, but the bucket with level float stays...Frost has a write up on it somewhere.....I will look for it when I get a chance
Old Jul 31, 2008 | 11:12 PM
AFASTYZFR1's Avatar
https://ls1tech.com/forums/showthrea...108&highlight=
this should help you out
