Will 60`s work?
Old Jul 29, 2008 | 09:30 AM
sjones99's Avatar
Default Will 60`s work?
Currently i have a 405 with T76 STS and i am running 60 lb injectors with a twin pump nasty performance fuel setup,The question i have is i am switching to a gt47r-88 and was wondering if the 60`s will be enuf.Right now running 18 lbs of boost and want to run 20-22 with the 88,Thanks.
Old Jul 29, 2008 | 11:41 AM
ZL1Killa's Avatar
how much power do you plan to make? around 700-800 i think you will be fine
check out my fuel and inejctor sticky and check out the link under it to RCENG.com and the technical sizing page
Old Jul 29, 2008 | 11:47 AM
sjones99's Avatar
Allready makin that..car went 10.21@134 weighing 3900lbs.
Old Jul 29, 2008 | 02:52 PM
ZL1Killa's Avatar
well what was your duty cycle and how much MORE power to you plan to make?
900? 1k?
you may have to invest in racetronixs 79# injectors or even larger and go to a controller box so you can use the low impedence injectors
