Losing 20 psi bliping the throttle.
Hey I just got my conversion done on the lt1 to ls1 swap. Im running lt1 factory lines off the fuel tank, they go into a vette filter with the built in reg. The fuel pump is outta a 01 ws6. With the motor ideling the pressure stays a constant 59psi. I was curious the other day so I put the gauge on this and checked it with the engine running in nuetral I blipped the throttle and it dropped to 45 psi. I checked to see if the fuel was bleeding off but it wasnt doing that either. My guess is the pump is weak.
Anything else to try or does everyone agree?
