2006 Gto Ls2
Old Aug 6, 2008 | 11:49 PM
kochevy67's Avatar
Default 2006 Gto Ls2
Do you guys know if you need to run the vent for the fuel system that is up by the intake. I bought a motor complete and they cut it. I am installing it into Chevelle and I am buying a gas tank for the car. Also do these motors usea return line because I did not see one near the fuel rail. Do I need to run a vette filter with a return in it or what?
Old Aug 7, 2008 | 12:15 AM
Drew04GTO's Avatar
That vent is for emissions only, since its going in your Chevelle just cap it off. All LS1's use a "returnless" system. You'll need to figure out how to get a regulator inline near the tank, if you want to use stock fuel rails. Or, upgrade to aftermarket rails and have a return type system.
Old Aug 7, 2008 | 12:34 AM
kochevy67's Avatar
Thanks I appreciate it, I can plumb a regulator in before the rails. I figured it was for emisssions but was not sure. I am going to use 6AN line from the tank to the rail so I will plumb one in before the rail.
