Question about t-fitting on gas line
any help is appreciated!!
So. I was goin to get a -6 Russel T fitting, and run the stock feed line. Then "T" it after the filter. Then cut and flare the line after the filter, put a flare cat/tube on it..hook it to the T and T w/ a -6 fitting and 3/8 line and use a russel sending unit billet adapter back to the tank. Does this sound correct? Then i'll have most of the lines I need for when I eventually run a return style set-up.
