Racetronix fuel system
Old Aug 31, 2003 | 02:01 PM
oOoLy's Avatar
Default Racetronix fuel system
my friend have this fuel system on his car but after installing the system, when he rev it or drive , it doesn't response properly. what is wrong with it?? do I need programming????
Thanks
Adnan
Old Sep 1, 2003 | 04:14 PM
oOoLy's Avatar
Default Re: Racetronix fuel system
ttt
Old Sep 1, 2003 | 06:37 PM
Racetronix's Avatar
LS1TECH Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Did you check the fuel pressure?
For tech support please contact the dealer who supplied the system or email support@racetronix.com. Contacting the people who sell and service the product should be your first step in dealing with tech issues.
Racetronix
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
Old Sep 2, 2003 | 04:34 AM
The Emperor Of Darkness's Avatar
the fuel pressure has not been checked!!! what should it be at??
stock injectors are still on the car(98 model)
Old Sep 2, 2003 | 09:14 PM
Racetronix's Avatar
LS1TECH Sponsor
58PSI minimum. Possibly a few PSI more at idle / part throttle.
__________________
>WEB SITE<
Old Sep 3, 2003 | 02:05 PM
ONEBADWS6's Avatar
My car has the stock regulator with the dual racetronix pumps, pressure at idle is 70psi. After tunning out my 8-1 AFR the car runs great.
Old Sep 3, 2003 | 02:45 PM
how to tune it????
Old Sep 4, 2003 | 02:48 PM
ONEBADWS6's Avatar
LS1 Edit at Speed Inc
Old Sep 4, 2003 | 05:16 PM
JF WS6's Avatar
You shouldn't need to retune the car just because of adding a new fuel pump should you? I would think that just an adjustment of the fuel pressure via an adjustable regulator might be all that is needed?
Old Sep 5, 2003 | 01:51 AM
mhoward's Avatar
My pressure went up about 6-7psi after my fuel pump install (Walbro 340), and I seem to have lost some power and I can see the rich mixture in the rear view mirror at night. Anybody know an easy way to get ther pressure back down?
Old Sep 5, 2003 | 06:43 AM
Chris99WS6PWTMET's Avatar
Adjustable Fuel Pressure Regulator
Old Sep 5, 2003 | 11:11 AM
JF WS6's Avatar
Is there an adjustable FPR that will mount to the stock fuel lines?
Old Sep 5, 2003 | 03:10 PM
ONEBADWS6's Avatar
I did did heads as well so I just retuned
