stock fuel pump problem?
Old Aug 20, 2008 | 09:57 AM
camsom's Avatar
Default stock fuel pump problem?
ok i have a 01 TA its been sitting for about 2 1/2 years just got a motor back in it and the fuel pump is not pumping. checked relay ,fuse and another pump that i had laying around although it has been laying around for awhile gonna try a pump that i know works tonight but was wondering if there was anything else it could be that i have'nt checked? thanks for any suggestions you may have !
Old Aug 20, 2008 | 11:29 AM
Nasty N8's Avatar
These pumps after sitting will get a crust in them and stop working. If you have power going to it it should run.
Nate
Old Aug 23, 2008 | 11:45 AM
camsom's Avatar
hey guys so i have a wiring problem for sure any one have a diagram to hot wire the stock pump? or any ideas where i have messed up?
Old Aug 23, 2008 | 09:43 PM
sreve's Avatar
here ya go, see the pdf
pull the relay and jump it with a fused wire.
File Type: pdf
