car just quit, possible fuel pump?
I think it could be the fuel pump
- Mike
a security fault will keep it from starting as will a blown fuse.
it ran out of something spark fuel and compression is all it needs.
if you do not have much to work with a shot of ether could tell you something.
i have seen a bad IAC before where the car would run with my foot on the gas but as soon or shortly after i let off it would die out.
Close; air,fuel and spark is needed for an internal combustion engine.
Can the I.A.C.'s be cleaned off and ohmed to check them???
